Gaming PC upgrade advice needed
I wont be able to do a bank transfer until friday at the earliest, so might just add a cooler onto my ocuk order. Thanks for the offer though!
Hey, bumping the thread here. I have kept my same PSU, but recently got a radeon r9 270x from overclockers, but my current graphics card uses one 'pci' 6 pin power cable from my psu. Looks like the r9 needs 2 x 6 pin cables, but there is only one 6-pin pci output from the PSU. There is 2 unused SATA 6 pin connections or another pci connection but it is 8 pins, can I use either of these from my PSU to connect to my new graphics card?
there is no cable in the 6 + 2 pci slot!
If you don`t have the modular PCI-E cable, then I don`t know what to recommend, other than getting a new Psu. Unless of coarse, you can get in touch with Zalman and get a replacement cable. Although from pass experience with Zalman, I think that will be highly unlikely, as they will just pass you on to a couple of retailers, who can`t help.
