** Coming Soon - Special Pre Order Price - Silverstone SST-RVZ01 Raven Mini-ITX **
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
Coming soon we have this excellent case from Silverstone.
Following on from the Raven success in the past, this console replacement chassis is perfect for your gaming PC in the living room.
You certainly will not be running out of STEAM when you are thinking outside the BOX with this chassis.
Silverstone SST-RVZ01 Raven Mini-ITX - Black @ £49.99 inc VAT
Since the debut of the original RAVEN RV01 in 2008, the RAVEN team demonstrated at Silverstone many times as it can truly define and meet the expectations of computer enthusiasts with regard to the capabilities of a powerful PC in form and function. For 2014, the team set a new objective: Exceeding and transformation of the SFF (Small Form Factor) Landscape with another groundbreaking housing design. The result of this effort is a new range of housing products named RAVEN Z. The first model, the RVZ01 lifts completely from all previous small form factor case from Silverstone from. Thanks a PCIe riser and custom fan, this slim 14-liter enclosure accommodate the largest graphics cards on the consumer market - with excellent air cooling and the ability to support liquid cooling solutions *. Designed for use in both vertical and horizontal orientation, it can be easily set up at all cramped places where a powerful PC is needed. Who would want to change with the help of a truly remarkable housing on computers with small form factor, struck gold with the RVZ01.
Specification:
- Characteristically RAVEN-style
- Supports graphics cards up to 33cm
- Mini-ITX motherboard, power supply SFX-enabled
- Maximum performance in slim form factor with support for liquid cooling
- Pressure design for excellent cooling, low noise and preventing dust formation
- Fits in nearly any environment with horizontal or vertical orientation
- Material: Plastic outer housing and steel frame
- Colorblack: MotherboardDTX , Mini-ITXDrive bays
- External: Slim optical slot-in drive x 1
- lntemal: 3.5 "x 1, 2.5" x 3
- Cooling: Cover1 x 120 mm fan, 1500rpm, 18dBABottom1 x 120 mm fan, 1500rpm, 18dBA 1 x 120 mm
- Slots: 2
- Front connectors: USB 3.0 x 2 audio x 1 MIC x 1
- Power Supply: SFX
- Graphics Cards: Compatible with 13 "long expansion cards, broad restriction - 5.88", width restriction
- Limitation of CPU cooler: 83mmNet Weight3.71kg
- Dimensions: 382mm (W) x 105mm (H) x 350mm (D), 14 liters.
- Extra: Supports Kensington Lock
Only £49.99 inc VAT - PRE-ORDER ONLY PRICE!!
ORDER NOW
I must say that looks rather nice, suprisingly low price too! Only problem is I was debating on an MATX build, but now do I go even smaller? :o
How will this handle a 2500k, sapphire 6950 toxic unlocked to 6970(can't expect to use xfire right? :p I have 2 x toxics). What psu would be need and what CPU cooler?
SFX psu is needed, probably with the highest wattage you can afford (obviously from a decent brand). CPU cooler will be limited to stock or other small low-profile coolers that won't obscure the PCI-E slot or RAM.
ST45SF should cover you for anything except heavily overclocked or dual GPU cards.
As for CPU cooler, I wonder if an AIO water cooler will fit? There's certainly enough CPU clearance to fit the block.
It actually mentions it has holes for a laing DDC pump so someone in the design team reckons watercooling can happen.
Block/pump would definitely fit, can't see where the radiator could live though.
there is watercooling support but it will be limited
official pricing has been confirmed by Silverstone to me this morning. The case RRP is around £64.99
We will be honouring the price in the OP until we get stock which could be just a few weeks.
Pre-order price now says £69.98 ...
What happened to honouring the pre-order price of £59.99 ??
We got limited stock, it fulfilled some backorders but not enough to fulfil all of the orders. We are looking at another batch landing next week at some point.
