- 25 Nov 2011
- The KOP
Another thing I will be doing is a custom fan profile. Have both cards start at 40% on stock auto they drop to 18% on idle that's to low for me.
Guys is it good idea to have same fans intake and out take? I already own two 140 apache black fans that will go in front of the case. If I was to buy another two for at top of the case that a good idea?
http://www.overclockers.co.uk/showproduct.php?prodid=FG-064-AK
Now Greg, you can't expect him to do that, imagine how much worse the Star Swarm demo would run!Shanks, send them back and grab a pair of 780's. Much cooler and less hassle![]()
I think It's just finding the correct air flow for this case tbh you do have good idea about switching them around and see if they give same result.
Think I'm gonna put one of those 230mm Bitfenix Spectre's on the side of my 500R, apparently they fit the 200mm holes.
On my haf x the front and side fan are intakes and the rear and top are out.
What I have noticed playing BF4 is my GPU usage on both cards is all over the place but gameplay is very smooth.
It's not like my 7950's were they kept the same usage.
ULPS is disabled and 50+ on the power slider.
Dust filter
Before I buy a crap one lol they loads to pick from. What the best 140mm fan filter? I going to put my H80 as intake but no dust filter on the back this case.
You might want to consider trying a positive pressure set up. Try switching the top fan to also pull in. Having more air being pulled in than being pushed out means that air will naturally be forced out where ever possible, usually via the vented area near your PCI slots.
Good news on the temps. Use beta 18 of afterburner, much more consistent gpu usage.
