one of these: http://www.overclockers.co.uk/showproduct.php?prodid=GX-305-AS
Or which 270x, there seem to be a few on ocuk.
one of these: http://www.overclockers.co.uk/showproduct.php?prodid=gx-305-as
? one of these http://uk.msi.com/product/vga/n670-pe-2gd5-oc.html, I bought mine from the MM for about £150
Thanks! will order the memory, cooler and have a look for a gfx card tomorrow!
Ok, I will have a look tomorrow and get back to you, about to head out just now.
Good cooler if a bit annoying to fit![]()
I wont be able to do a bank transfer until friday at the earliest, so might just add a cooler onto my ocuk order. Thanks for the offer though!
I believe the 8pin is actually a 6+2pin, they should slide apart, just plug in the 6pin part.
Ye it looks like that. If so am I OK to order a 6pin plug and connect it up?
there is no cable in the 6 + 2 pci slot!
