The fuel saving is massive - typically 30-40% - when covering a route and coasting where feasible, compared to the same route when the engine is in gear and providing engine braking. When you're in a gear, the ludicrous the number of times during a journey you for example, see traffic lights 800 yards ahead, accelerate up to them, the brake to slow down.
Yes, its potentially an offence to be coasting but these days with DSG and gears engaging in a few milliseconds, I cannot see why there should be any safety disadvantage. As soon as you touch the throttle for example, the car snaps into gear with a DSG type box.
Government needs to add a 'carve out' in the legislation of the wording to allow for coasting if its built into the car through the gearbox and manufacturers should think about implementing it.
No No No
This used to drive me insane when I was 17 and my friends thought by putting the gear in neutral and coasting down a hill they were saving fuel.
Why do you think it's impossible to stall in neutral or with the clutch dipped? That's right - because in simple terms the car is feeding the engine petrol to keep it ticking over.
On the other hand, if you keep it in gear and allow the car to slow down enough it will stall, because there is no fuel being injected into the engine to keep it going. Therefore you are better off leaving it in a high gear when going down a hill. (Edit - by this I mean a slight downhill gradient, not a demon slide)
Someone correct me if I'm wrong.
