This thread is just the ultimate face palm.
As discussed in gear as soon as you take your foot off the accelerator the fuel injection into the engine is cut off. In neutral there is always fuel being injected into the engine to keep it ticking over which is why you cannot stall a car in neutral or with your foot dipped on the clutch. Therefore on a downhill gradient you are using less fuel by sticking it in the highest possible gear as opposed to putting it in neutral.
