Does anyone have any experience with any of the Porsche car clubs? I'm not too sure which one to join, if any.
911uk is good and PH.
996 turbo here![]()
looks very nice.
I started looking at 991's now, But I am really struggling to see the value in an extra £30k over my car (which is only a 2011) I would love to get into a 991 but they seem to be holding their value very well at the moment.
Any Idea when the 991.2 is due?
Very nice indeed!
I'm trying to convince myself my next car should be a 911.
Problem is the wife has a Mini so where do we put the luggage when we go away?
And how do I manage those tip runs?
Rent a van and you can easily fit luggage in a 911. Loads of space behind the rear seats (assuming no kids) and plenty of space in the nose. Life is too short to find reasons for not doing something, last year showed me that with friends losing their lives far too early. If you want a Turbo and can afford a turbo, you MUST buy a turbo as you never know what tomorrow brings. No one EVER lay in bed worrying about the fact their car couldn't carry a case or some old boxes. DO IT!![]()
replaced with a suitable Bosch number and everything is fine now.
Hmm you know this will void your warranty?
Yep, Porsche will not review warranty with that in place, even though its a better battery.
If your going for warranty again and need a battery I will swap you with my one at next RR meet or something, if that helps?
That's crazy, the OPC wasn't open and I needed a battery so got one that matched the exact spec of the original.
The car still has 15 months of warranty left on it and it'll be sold by the summer - I assume they won't void the current warranty or turn done a claim on say a gearbox, clutch or something because of a different brand battery?
They could yes, however my old 997.1 had a new engine put it and they did not notice the bosch battery however if they did I think they would have voided the whole claim.
Trade your battery with Gibbo if he wants.
Need to start considering what to get really!
As I'm only likely to do another 2k-3k over the next few months in the car before I sell it I'm hoping to not need to go back to my local OPC and this wouldn't be a worry.
I can't see how they can deny a claim for say a gearbox if I fitted an equal battery a month before or something. I think the 911 battery is different to the Boxster anyway so not sure Gibbo's would work / fit.
I'll be glad when I don't need to rely on my local OPC and can go to my local favourite garage for work.
If you don't know what you want, why change?
I understand what you are saying but at the end of the day you are in breach of the terms and conditions set out in your contract so I would think they can turn down your claim.
I would suggest you get a 997.2 for your next car.
Stop worrying!
The battery won't void a claim, but they won't refresh your warranty with it in place, even though its better than the crap Porsche sells for twice the money.
Take a photo of your battery and post it up, if its same spec/size I am happy to swap as I won't be getting a warranty on mine again, remap, different throttlebody, exhaust system, GT3 suspension, LOL.
Though they did warranty work on mine with GT3 suspension, steel turbo brakes, larger throttle body in place, though I did remove the remap and cats before going for warranty work.![]()
