Power Supply Enough
17 Oct 2002
Leeds
Hi there.
Would the Seasonic G Series 360W PSU be enough for the following:
Intel 4670K overclocked 4.2-4.4GHZ
Gigabyte Z87 X UD3H
Creative X-Fi Xtreme Gamer
WD VelociRaptor 150GB
DVD Rewriter
Antec 1200 (upto 7 case fans)
Team Vulcan 2x4GB 2133MHZ
Thermalright Silver Arrow Cpu Cooler
Ati 4850 Gpu
If it is close I can remove the Ati 4850 and use the IGP of the Haswell. If either way 360w is not enough would the Seasonic G Series 450W be OK?
Thanks
200w?? Not according to every calculator on the net. On my opinion the 360 would possibly be ok but would be cutting it a bit fine.
Calculators are not always accurate (not to mention most of them show the recommended psu wattage, not the actual usage). I guarantee that system will never use more than 200w. It's not possible, just look at the TDP of his components.
