AMD Mantle Interview with Oxide Games' Dan Baker
Caporegime
24 Sep 2008
Essex innit!
Could Mantle be the next successor to DirectX?
Oxide Games developer Dan Baker helped answer some questions we had about AMD’s new Mantle API. Oxide’s upcoming game, Star Swarm, will support Mantle out of the gate and the company has been very vocal about Mantle which it believes can help all gamers and also start a dialogue about the future of APIs on the PC.
Maximum PC: Most believe Mantle is a low-level API that is very close to the metal. Can you explain why this concept is wrong?
Baker: Relative to Microsoft's Direct3D (D3D), Mantle is indeed more low-level. But it's not low-level in the sense that we are exposed to individual architectural decisions. For example, Mantle still abstracts the details of the shader cores themselves, so that we don't even know if we are running on a vector machine or a scalar machine. What isn't abstracted is the basic way a GPU operates. The GPU is another processor, just like any other, that reads and writes memory. One thing that has happened is that GPUs are now pretty general in terms of functionality. They can read memory anywhere. They can write memory anywhere. A lot of the things an API has traditionally managed aren't really necessary any more. Mantle puts the responsibility onto the developer. Some feel that is too much, but this really isn't any different than managing multiple CPUs on a system, which we have gotten pretty good at. We don't program multiple CPUs with an API, we just handle it ourselves. Mantle gives us a similar capability for the GPU.
Maximum PC: You’ve said Mantle really addresses the inefficiencies of DirectX which was architected in the 1990s. Can you give us some examples of the inefficiencies of DX? We know you’ve mentioned DrawCalls as an example.
Baker: DirectX was architected in a time when two things were true. First, the hardware itself was very fixed-function. That is, there was a lot of secret sauce as to what exactly it did. As shading models became almost completely general, the need to abstract this level become less useful. The best way to think of a GPU is just a processor that runs programs. All we really want our API to do is give us a means of executing little programs on the GPU. This programs are what's in a batch, or a draw call. We don't want it to manage memory, we don't want to 'make things easier for us.'
Oxide's Star Swarm
Oxide's Star Swarm RTS promises a huge boost in performance when running AMD's Mantle API
The second problem is that APIs are still designed in this functional threading model where you have a series of processes that pass work back and forth to each other. The idea is that you have say, one thread for rendering, one thread for audio, one thread for gameplay, etc. This is a really not a scalable way to build things. In situations where you have a shared L3 cache, you also create contention from all the different processes running, since they all access completely different memory. The industry continues to move to a job-based setup, where we have lots of tiny jobs that run asynchronously. This can now scale to a large number of CPUs, and we can fill up most of the previously unused time where one of the processors isn't doing something.
Maximum PC: Does OpenGL face the same limitations? It’s also a pretty old API at this point.
Baker: OpenGL has essentially all the core problems of D3D, except that one can add extensions to it. The main difference between OpenGL and D3D is that D3D made an attempt to be threaded, and failed, whereas OpenGL has not yet attempted it. One question is whether it is worth building a new API or making a bunch of extensions to an existing API. You can get some mileage out of making extensions, but extensions can't bridge things like being able to use multiple CPUs. Also, at some point it's cleaner and easier just to hit the reset button, rather than throw yet another feature in a fairly big API. Believe it or not, Mantle is actually easier to support than OpenGL. OpenGL has many unobvious pitfalls and traps, whereas Mantle really doesn't.
Oxide Games and Mantle Presentation Demo
Maximum PC: There have been some pretty wild claims of performance increases by going to Mantle. How much have you seen in your game?
Baker: This depends on how exploitative you are, and the specifics of your engine. For us, we have been completely limited in what we could do by driver overhead problems. We were actually making decisions where we traded GPU performance for CPU–that is, we’d end up doing things that are slower on the GPU, because we could get away with less driver overhead. When you talk about building an FPS, you probably spend much of your time optimizing for the GPU; when you try to build an RTS, you end up optimizing for the driver overhead. Nitrous is a new breed of rendering system. Oxide’s specialty is high throughput.
When you look at Star Swarm, it's really a testament to brute force. For us, we can see cases where Mantle is many times faster, with especially big differences as we add more cores and slow down their clock speeds. We wouldn't expect most games to necessarily see this, as it will happen in cases where you have a really efficient, high throughput engine, but it will certainly make an impact everywhere. We aren't set up to do very precise testing, so we'd rather others do the analysis on this. However, we'd like to point out that our Direct3D performance is absolutely outstanding, relative to what is expected. We have spent a huge amount of time optimizing around D3D, and we feel we are actually pretty biased in D3D’s favor. Mantle, on the other hand, we've spent far less time with and currently have only pretty basic optimizations. But Mantle is such an elegant API that it still dwarfs our D3D performance.
Maximum PC: It seems that the main challenge for Mantle to succeed is getting support from Nvidia and Intel. Do you see that as actually happening from a developer point of view?
Baker: Yes and no. Mantle does detract from other platforms, and we are already seeing a big dialogue in terms of what future APIs should look like. Mantle is kind of the disruptive technology that gets everyone rethinking things. Whether this means a new version of OpenGL, or a new version of D3D, we can't say. But it is clear that they will have to adapt if they want to stay relevant. Some of us have been screaming for change for years. The arguments we got in the past were: 1) it couldn't be faster 2) it would be too hard to use, and 3) we have enough performance, so more isn't useful. We wanted to show that all three of these things are provably false.
Maximum PC: Do you see a world where developers will have to write for DX and Mantle? How much of a challenge is it to write for both APIs?
Baker: APIs come and go. Once you support more than one, it's pretty easy to support a dozen–assuming there is parity in the hardware features, and assuming you don't have to rewrite your shaders in an entirely different language. If you release a title right now, you would end up with likely six paths. An Xbox360, a PS3, a PS4, a Xbox One, a DX9, and a DX11. For us, the graphics system is just a module that talks to the API. All we did for Mantle was replace the D3D module with a Mantle one. It's about 3,000 to 4,000 lines of code for the Mantle version, which took me personally about two months to write. In terms of support, at least for us, it wasn't terribly difficult.
An interesting read :)
I can think of a few currently lol.
Well, I can't use it...
not really a pitfall or trap within the meaning of the interview. Your just unsupported in its current Beta form, due to your hardware choices... Something AMD look to expand going forward, when & how is not known at this time.
Greg posts a good interview & you drop fan boy in post 2, Frosty we all get your with the green team, but maybe take the interview for what it is not what you want it to be.
He has not made a fan boy comment, he has stated a fact. You seem to be the one with issues over it. Let me guess you have a AMD GPU?
? Wasn't a fanboy post at all. You understood the context in which I said it, so why explain it back to me. NV won't adopt Mantle, so it is a pitfall. Not pointing fingers at any one thing, just as a consumer currently, and for the foreseeable future.
Calm down Jock. :)
Have reading through that, I honestly think whether or not Mantle is going to be successful, it is still a good thing that AMD had decided to develop and release it, as it would more or less getting Microsoft and Nvidia to think outside the box and possibly about changes, rather than continuing to hold onto dx that is known to be not exactly the most efficient way of doing things.
If Nvidia/Microsoft refuse to adapt Mantle and decide to release a new dx/api instead, that is still good for all of us, as it would bring more competitions, and we as the consumer would get more performance out of the graphic cards that we paid for.
The part about OpenGL is rather interesting as well. I know everyone been talking about the possible merit of using OpenGL, but nobody seem to actually thought about the possible shortcoming or limitation of it. It might have the potential to be better than the current dx, but the question is- how much?
Best to use the ignore feature on this one Jock.
lol, pathetic springs to mind. Some of you really need to stop taking it all so seriously.
It's a comment valid to practically half the market if not more, and is brushed aside as being bias.
So, so defensive.
My only worry about all this is that at the moment, you can buy either AMD or nVidia card and play any game well. Sometimes there are issues in either camp to begin with that are quickly resolved.
However, i fear that if there starts to be a divide in APIs between the camps and money exchanging for performance, then there could be a time that an nVidia user loses out playing game X and AMD user loses out playing game Y.
Im sure this won't be the case, but it's still there niggling at the the back of my head.
I'm not going to jump into he said she said over this, i asked you to share the "few" pitfalls or traps you had spotted, so I was thinking maybe you had some better understanding of how coding in Mantle into a game engine would be an issue, clearly now that's not the case, as you came back with "i cannot use it", that's not what the interview was about or the context of the highlighted part in your post.
So the question is why post at all?
yes i have AMD, my last 3 cards of been AMD, the 4 before it where Nvidia had a few matrox cards as well, does it make any difference I'm not sure it does.
I like tech & the things it brings to gaming, its that basic to me,
Why shouldn't I post? I'm a consumer with a high end GPU who cannot use this technology. I hate to bring it up but it's a fair argument, how is it any different to all the whining from people who can't use PhysX. It's not, consumers don't like being locked out. You don't have to start kicking your toys out of the pram for no reason, it's not a personal dig at you, is it?
What's the point in putting an API into beta if you're restricting your test base to a small portion of an already niche market to people with GNC based hardware.
It'll be 2017 before it's ready lol. I'm wrong though apparently.
Because they can actually own a Nvidia card and still can't use the feature?
:rolleyes:
O.K, well best of luck to AMD and all their die hard fan base. Not like we've seen proprietary APIs before is it.
Leave your logic hats at the door folks.
Have to agree here, Mantle has caused nothing but issues for me!
If I had the money, a 780/Ti would be on the table!
I assume you mean using an AMD card to render and then the Nvidia card to do PhysX.
Not exactly the same, but you can own an AMD card, have it in your system, rendering on your Nvidia card and can't use Mantle :p
People don't whine about not being able to use PhysX, they hate it for being a roadblock to open standards that Nvidia stubbornly continue to tout as a value add but can only ever be used for mild aesthetical trimmings as long as at least 1 other company has any kind of market share.
But the difference is that Mantle is part of the main part (if not core part) of rendering, whereas Physx is a post-processing graphic feature that has worked with people appling a simple hax for it? (Granted the hax no longer work now).
Right?
So how is this any different? Because it will do in the future?
Maybe I've been around too long...I'm not doing this on purpose. I'd never praise PhysX as a technology, I'd rather it left to everyone else as much as anyone.
