I'm a bit new to using these forums but a long time overclockers customer. I'm building a new rig so I thought I'd make a project post for anyone interested.
I bought an MSI 290X gaming about 2 weeks ago because I felt like I just needed to upgrade my 2x 6950 crossfire setup, unfortunately I caught the bug and decided its time for a new build, it's been a while. I don't really need a new build, but I want one
I was originally just going to add a second 290X, put my existing build in to a new case, and watercool it all, but I decided to go all out. The only thing's being recycled will be my 850W Corsair modular power supply (should be sufficient) and my 120GB and 500GB SSD's.
This will be only my second venture in to watercooling, my first being about 8 years ago when I bought a kit. Compression fittings etc appear to have made it easier and more accessible so I'm looking forward to giving it another try.
Here's my basket:
YOUR BASKET
1 x MSI Radeon R9 290X Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card £449.99
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £269.99
1 x Asus Z87 MAXIMUS VI FORMULA Intel Z87 (Socket 1150) DDR3 ATX Motherboard £249.95
1 x Phanteks Enthoo Primo Full Tower Case £199.99
1 x Avexir Blitz 1.1 Original 8GB (2x4GB) DDR3 PC3-22400C12 2800MHz Dual Channel Memory Kit (AVD3UH28001204G-2BZ1) £179.99
1 x XSPC D5 Photon 270 Reservoir/Pump Combo £139.99
1 x XSPC RX480 Quad Fan Radiator V3 £105.95
2 x XSPC Razor R9 290X / 290 VGA Waterblock £94.99 (£189.98)
1 x XSPC RX240 Dual Fan Radiator V3 £64.99
1 x XSPC RayStorm CPU WaterBlock (Intel) £51.98
1 x Akasa 5.25" FC Six Channel Brushed Aluminium Fan Controller (AK-FC-08BKV2) £24.98
2 x XSPC Razor R9 290X / 290 Backplate £24.95 (£49.90)
3 x Corsair SP120 Performance Series High Pressure - Dual Pack (CO-9050008-WW) £23.99 (£71.97)
1 x XSPC LCD Temperature Sensor (White) V2 + G1/4" Inline Sensor £8.99
2 x Mayhems X1 Clear Premixed Watercooling Fluid 1L £7.99 (£15.98)
10 x EK Water Blocks EK-CSQ Adapter 90° G1/4 Black Nickel £6.95 (£69.50)
2 x EK Water Blocks EK-CSQ Adapter 45° G1/4 Black Nickel £6.95 (£13.90)
2 x XSPC HighFlex Hose 7/16" ID, 5/8" OD, 15.9/11.1mm, 2m, Black £5.99 (£11.98)
18 x XSPC G1/4" to 7/16" ID, 5/8" OD Compression Fitting (Black Chrome) £3.19 (£57.42)
Total : £2,247.65 (includes shipping : £16.85).
I bought a few spare fittings and a couple of 45 degrees just in case, but I think 90's will work best. The only thing missing is a few white LED's which I'll order later. The res comes with white, but the blocks come with blue which I won't be fitting as I want these to be white as well.
My plan is to mount the res/pump on the braket in the case, 480 at the top pushing out, 240 at the front pushing out, and the 140mm fans that come with the case will go in the bottom pulling air in. loop will be:
res/pump - GPUs - 480 - motherboard - CPU - 240 - res/pump
Delivery will hopefully be tomorrow, when the build starts, so expect pictures then
Here's my basket:
YOUR BASKET
