- 30 Jan 2014
is it worthwhile paying the 70 quid or so extra to get the 4770k when main uses will be gaming?? undecided whether i should pay the extra and what sort of advantages or gains would there be
The i7 has 4 cores and 4 hyperthreading cores. (Shows as 8 threads)
If only gaming with a single gpu, the 4670k will be grand. If you intend to go sli/xfire at some point there are a few games at present that benefit from the extra threads on the i7.
that doesnt make any sense to me tbh. is it similair to the fx8350 then? when you have cpu monitor installed it shows as 8 cores even tho its basically 4 cores. or am i completely wrong there
i will be doing xfire straight away, im looking for best performance possible and hopefully something that will give me 2-3 years before any upgrades are needed
Have you already got the board? Reason I ask is cause for 40 quid difference going true enthusiast like for like on boards is IMHO a no brainer its worth it for the soldered IHS if nothing else
YOUR BASKET
1 x Asus X79 DELUXE Intel X79 (Socket 2011) DDR3 Motherboard £279.95
1 x Intel 4820K 3.70GHz (Ivybridge-E) Socket LGA2011 Processor - Retail (BX80633I74820K) £239.99
Total : £529.54 (includes shipping : £8.00).
YOUR BASKET
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £269.99
1 x Asus Z87-DELUXE Intel Z87 (Socket 1150) DDR3 ATX Motherboard £209.99
Total : £489.58 (includes shipping : £8.00).
You've picked a cripplingly expensive Z87 board there, which skews the comparison making the socket 2011 solution look more favourable. The real difference is likely to be +£140 to go socket 2011 vs 1150. however your point still stands.
X79 (socket 2011) offers:
2 x16 PCIe lanes (Z87 = either 1 x16 or 2 x8)
Quad channel RAM (Z87 = dual channel)
Z87 however is the newer chipset and as such includes native support for the latest technologies.
Unless you've got money to burn, for a gaming system a Z87-based solution (and I would recommend a Gigabyte motherboard for Z87) will perfectly capable.
i received a gigabyte z87x-oc yesterday from ocuk so will defo be needing an 1150 cpu
