I just got an Email from an AMD engineer today.
Thanks Warsam71
Thanks Warsam71
glad there working on it for you
It is good that they are working on it and hopefully will get it sorted.
At least they've reproduced it which means its not faulty parts or user error![]()
Good work. I directed Sam to this thread via email after Karl posted the thread.![]()
Thanks so much Matt, I was about to sell my cards to get some GTX 780ti but its really not what I want.
Thanks Warsam71
Excellent! I'm happy to be of help and will continue to keep an eye open...![]()
While we have you here can a draw your attention to this?
http://forums.overclockers.co.uk/showpost.php?p=25838263&postcount=923
Its getting quite frustrating now.![]()
Considering that was in the 'known issues' of the 14.1 drivers id say a fix is already underway and will come in a newer driver build.
Just do some bug reports, they will acknowledge your issues for sure. Doing so in GOOD details will help them solve the issue much better.
I do around 3 or 5 for the same issues each time I find a bug.
i may send another one.
Hello Karl,
I just received an email from the guys in Customer Service which have been working on the issue with Engineering.
They have identified the issue and are working on a solution which will be included in an upcoming driver release. To be perfectly honest with you we don’t know when this new driver will be released yet; but I will definitely let you know as soon as I find out.
Best,
Sam T.
, I hope it will take a month or less for a fix.
More updates from Warsam71![]()
Thank you very much, I hope it will take a month or less for a fix.
+1 to amd sorting it for you and other users![]()
Yeah, I am very happy, I feel bad not to have created a thread earlier, I fought for a month and a half with that issue trying to troubleshoot it and figure if it's user error or driver fault
Its the best way to get a bug fixed. Send a detailed report so they can replicate it. Providing a video (if applicable) can help as well. Its easy to sit on a forum and moan that achieves absolutely nothing.
