Hey guys, been working on the new rig and ran into a slight issue.
Using the Fathom cooler due to space limitations.
Initially the rad was going to be other way around closer to the I/O area however due to the block on the back of the Rampage IV BE it interfered with the tubes exiting the Rad. So the rad tubes had to go into the Optical bays.
I got the tubes cut to the exact length I measured for the other configuration, however they did spend spare tube which is a plus.
Currently it's all fitted however not personally happy with how this tube looks, the other one is completely fine length wise with no visible signs of bending.
Does this look alright? More concerned about it pulling off the fitting is anything as the bend is right on the fitting.
If needs be I can cut the spare tube to a longer length and swap the tube over. Is it worth doing?
Also with doing this what is the effective way of refilling the Fathom/Eisberg pump/res?
