Infinity Quasar - what would you change?
6 Nov 2002
I'm potentially looking at getting a new rig, always fancied a watercooled setup and I need something to cheer me up.
If you were to buy/customise the Infinity Quasar to your perfect spec, what would you add/change/remove?
What acme said.
That rig is perfect.
But if you want a custom rig, best to build it yourself from premium components.
Then you will be sure and fully satisfied.
Start with looking inside your wallet :-)
After that you can go where I went - Case Labs site ( best custom case manufacturer in my opinion ).
Actually, I personally would get the white Leadex Platinum 1000W for the aesthetic, and a Xonar Essence STX for my music, but I don't know if high quality music is your thing. :)
What acme said.
Thanks, I will take a look. My only issue with a self build is that I don't have the time or patience at the moment. I have a feeling I would end up rushing it :(
Thank you :)
I'd remove all the secondary storage drives. I already have two in my current PC and I'd be transferring them across.
That's the rig i'm looking to get, unfortauntly comes over my budget of £3000 so waiting slightly longer before deciding, I wouldn't change anything in that system as it's extremely fast.
