FIFA 14
He gets muscled off the ball so easily though. How do you stop it from happening?
How would Suarez go upfront along side Augero? Suarez is only 70k.
I don't find that at all I find he wriggles through ridiculous gaps keeping the ball where as other ST's either get knocked off the ball or tackled.
I do have Scurlle LM though which does help loads & obviously side show & Kompany come up for corners.
With Schurlle LM & Navas RM when on the break my team put the ball behind the defence & Aguero is there for the final touch.
Some of his goals are ridiculous his close control & the way he gathers the ball in cannot be beaten by any other ST.
Suarez. This is the one player that when you use him you feel a difference, He floats about under your control I loved using him apart from one thing & that is Goals. If he scored as many goals as Aguero I'd use him every time but he don't & nor does any other ST.
You can't use him to brush past people. You have to dribble past them or skill past them. Or just R2 jag round them. If you go shoulder to shoulder you'll lose. Messi will lose as well. You have to play to their (the smaller players) strengths.
Yeah I just need to use him properly. Not sure what R2 jag means? I know R2 is a dribble.
As others have said he isn't a player you can just run in a straight line with and shoot.
I've been using a lot of close dribble with him (l1) and he can get around defenders well. He's also really good just at normal pace with no other buttons held down when dribbling.
Van Persie is only 110k? He is worth having over Jovetic?
Have you unlocked the Skill Challenge for advanced dribble? R2 jag is where you hold down R2 and zig zag in different directions while maintaining speed.
They have you do it in the skill challenge racing against an obstacle.
You have to unlock it? I've done some of the dribble challenges. How do I know if I have unlocked it or not? :p
Wow I was confused.
I thought you meant that you actually UNLOCK a new dribble when you complete the final skill challenge.
Anyone else here using RVP and Aguero up front?
