BitFenix Alchemy Premium Modding LED Strip - Connect Orange 60cm @ £15.95 inc VAT
Part of the BitFenix Alchemy Premium Modding Series, Alchemy LED Strips are the ideal choice when modding inspiration strikes. These precision manufactured LED Strips come with BitFenix TriBright™ LED Technology for the absolute brightest LED strips available. Alchemy LED Strips come in both chainable Connect and waterproof Aqua, and offer a multitude of lengths and colors, enabling you to bring your modding vision to light.
When only the brightest will do, BitFenix TriBright™ LED Technology gives you the industry’s brightest LED strips. TriBright uses independent ICs to power each LED bulb for maximum brightness.
Alchemy LED Strips are made using a precision SMT manufacturing process, which means the highest quality, enhanced current conduction, and prolonged life.
Have a special idea that needs an extra-long length of LED strips? No problem. With Alchemy Connect LED Strips, you can connect as many strips together as you need with the only limitation being your power supply's current.
BitFenix Alchemy LED Strips are backed with high-grade adhesive from 3M™, which makes sure that your LED strips will remain where you left them, even when your computer is being moved around.
- Colour: Orange
- Length: 60cm
- LEDs: 30
Only £15.95 inc VAT.
ORDER NOW
_____
NZXT FZ-120 Airflow Fan Series, Orange LED - 120mm @ £7.99 inc VAT
NZXT proudly introduces its newest series of airflow fans, the FZ-120mm LED fan. The FZ-120mm LED fan is a perfect match for any type of chassis. There are 5 available colors to choose from: white, blue, orange, green, and red. It is ideal for achieving high airflow with minimal speeds of 1200 +/- 20% RPM. The 13 blades provide quiet operation of 26.8 dBA and high airflow of 59.1 CFM. The long-life bearing provides better reliability and extends life span surpassing 2 year warranty. This 120mm fan is the coolest solution for any enthusiast in demand of extreme airflow.
• Optimized for extreme airflow 120mm fan with minimal speeds of 1200+/- 20% RPM
• Low noise level of 26.8 dBA with exceptional airflow at 59.1 CFM
• Long-life bearing provides better reliability and extends life span surpassing 2 year warranty
• Available in 5 LED vibrant colors: white, blue, orange, green, and red.
Only £7.99 inc VAT.
ORDER NOW
- Colour: Orange
- Length: 60cm
- LEDs: 30
ORDER NOW
_____
Only £7.99 inc VAT.
ORDER NOW
