FIFA 14
I'll give Benteke a try along side Jovetic.
Benteke is good and cheap. Very strong.
Clearly lacking in some areas though... :p
If I can adapt my style of my play I'm sure Aguero will be great. I just need to learn to dribble properly.
Ideally you want a pacey striker beside Jovetic as he is already well rounded.
Unless your spamming crosses then Benteke is pretty much crap tbh compared to say Etoo.
It depends a lot on your style of play, if you want a target man then get Benteke and Etoo, if you want an all rounder then get Jovetic and Etoo up top.
Pace makes a big difference so if you have 2 up top make sure 1 of them is fast even better if both are tbh because pace makes them better at everything including heading. Remy and Etoo up top would be good as well or Kone and Etoo.
He's obviously broken!
1 englishman!! :p
I do need to give RVP more of a chance, only used him once at CAM and as a link from Kluivert to Robben, he got rage sold faster than you can say Scooby doo!
Yeh i worded that wrong ill give you that :D
My BPL fitness team rocks!
I don't understand why people buy expensive strikers and don't even use them! This guy is doing nothing else except using the wings and just spamming croses hoping to get a good header.
They probably said the same of you when they saw you trying to tank your way through with Aguero :p.
Come on then pro. Upload some videos of you being awesome with Aguero?
