Crysis 2/3 Relentless Crashing
2 Jul 2012
Berkshire, UK
I haven't played a single game of Crysis due to the Crashing. The only issue I can think of is an issue with my 770. I've been contemplating sending back the card but at this point it could be something other than my card. A lot of other games used to crash but now its only the two Crysis games so it hasn't bothered me until recently. :o
System Specs:
i7 3770k @stock
MSI GTX 770 Lightning
8GB Vengeance Pro 1600MHz
Windows 8.1 Pro 64Bit
Nvidia 332.21 Drivers
Thanks Guys.
Anything in event viewer?
Ah! Found this.
That looks like a driver issue, I assume they are all up to date? How long have ou had the card?
does it crash to desktop? the games if so try one/two clicks more cpu v
also any whea warnings/errors in event viewer?
was it crashing before the beta drivers?
Yes. Every 3-10 Minutes.
Yes it does crash to desktop. If the crashing persists then I'll try a bit more CPU voltage like you said. There were two errors in Event Viewer (you can see them in the screenshot above).
Thanks guys.
those games are cpu intensive so most likely need touch more cpu v,classic sign if it crashes to desktop,one level higher llc will help if you don't want to add any cpu v
whea errors/warnings will tell you aswell
The Beta drivers have fixed it at the moment, but thanks for the info I'll gave that a shot if I continue to crash :cool:
