Yep,although you get consumer level drivers. However,the cost savings are massive over the equivalent Quadro.
You can install quadro drivers on any card.
So I see, like the Titan, the double precision performance owns the 780Ti so its use is in compute and development scenarios.
So for a gamer this aint the card for them, and maybe the 790 would be the better option.
The only instance the Titan Black makes sense over the Ti for someone who is purely gaming is if you are using 1600P + or NV Surround where the added VRAM is required. It's been confirmed that BE is the same PCB as a 780Ti.
I'm guessing dual 780ti's in SLI would be better than a single Titan for 1600P 144hz or other hefty requirements?
Most likely although I can see a few new games starting to push 3gb at that res.
lol you can't trade outside the MM, I don't want a ban or see you get banned.
That's why i used trust, obvious fail though![]()
I'm not positive but I'm pretty sure they can check messages sent through the trust system. Sorry it's just not worth losing MM access or risking a ban to do a deal behind the scenes.
Jesus! I would never have said Thundy likes wearing womens panties via trust if id known that.
