R9 290X Owners Thread
Just received my Sapphire 290x Tri-x OC from here & I have a small query, Advertised speed is 1040Mhz/5200 but mine is reading 1010Mhz/5000.
Yes I know I can easily correct that using afterburner but I thought it was factory overclocked out of the box.
Apart from that, it's so BIG!
My 290x
Which brand of 290Xs are you guys using so I can put you on the Roll of Honour.:)
Nice ^.
What's that long round thing?
Matt that is not normally discussed on these forums! ;)
That is the stilt I made left over from the 7990 to support it from sag. I created a template and was about to add two floor fans blowing up before I RMA'ed the card and now have the 290X.
Here is my 290X after having it a few days,
Never wanna do it again was so worried was going to break something but on down side bye bye warranty :(
And it all in and finished.
All at night with fluid finally in:
What brand of 290X are you using so I can out you on the Roll of Honour.:)
I think it would be fun to have a max temp comp for 290P/Xs
Go three times round the Heaven 4 bench @stock GPU clocks and record the max temp reached in GPUZ for cores and VRMs.
Benchmarking, or just a normal run? I'll give it a bash. What are the rules though? Are we allowed a custom fan profile or pure stock settings? I assume i can turn my case fans up a bit? :p
Can't do it now though, in the middle of uploading a video.
