If you say so.....Bodie, Doyle or Cowley, take your pick.
OK pro
They can make the fastest mobile GPU ever.... unless they give it the memory bandwidth to match it'll never compete with anything.
Imagine giving a R290 100Gb/s memory bandwidth, wouldn't really perform the same would it.
Stacked memory should fix the issue but even that's going to take a few years.
So when Carmack is negative towards Mantle he's not relevant anymore and nor is anything he says.
When Carmack is negative about this Nvidia K1 thing then it's proof that it's true?
It's good that the AMD people know when he in a lucid state and when he isn't cuz I can't keep up!![]()
You should be directing this to the author of the article.![]()
Did that author also says Carmack was irrelevant when he made his Mantle comments?
I checked the article, theres no mention of it. Not sure what it has to do with this thread.
Sure, it has a powerful GPU, but the idea that it can compete with gaming consoles is hyperbole unless they can actually show it side by side running the same game. Nvidia's Kepler GPU is incredibly efficient and there is no doubt that they can probably get some mobile games optimized for it to look console-quality or better, but the comparisons are clearly going a bit overboard.
Very true. They give us things that work, so us idiots don't have to keep messing with settings in AB/TriXX and whatever else that AMD need to do to get their cards working. Hats off to the AMD guys for having to use their brains to use AMD equipment![]()
I owned a Surface 1 and bought a Surface 2 at launch, they need to kill of RT.
Make a Surface X86 atom/AMD Jaguar , with the Surface build quality etc (And better speakers, they're a pile of crap)
Windows RT/Modern UI got San Andreas on the Window Store, that's a good move (But it's not really mentioned ANYWHERE, even finding it isn't as easy as it should be in search)
Jesus, the amount of trolling in this thread... Give it a break guys.
Interesting, what do you think of the Surface (2 especially) overall? I am looking into getting the Surface 3 this year as it would be incredibly helpful for me to get a lightweight device which can run Visual Studio 2013 without having to haul my laptop around which is pretty heavy and doesn't have a great battery life.
I've heard good things about the Windows 8.1 RT on the Surface, the metro style layout seems like it sure would work better on a tablet than a laptop or desktop.
Does Visual Studuio 2013 run on Windows RT (ARM)? I don't know.
It's quite hard to say how I feel overall.
With the Surface one, I absolutely loved the build quality, the speakers while quiet were of decent quality.
The Surface 2 seems a slight, slight downgrade in build quality for me (The kick stand feels flimsier) and the speakers crackle (I've had 2, so it's just the speakers being crap) at higher sound levels and they're a downgrade overall (You can negate the crackling by turning off tegra enhancements, they become decent quality, but useless if you're trying to watch netflix etc, as they're too quiet)
I love the Surface 2 in concept, it's a premium device (I wish it was running the Snapdragon 800 like the Nokia 2520 but meh)
Windows Store leaves a lot to be desired too, Microsoft has an OS that has strengths than Android doesn't have, but then it has weaknesses (Limitations, so things like PSX emulators can't exist currently with decent speed, yet you had 1GHZ Snapdragon single cores doing emulation ages ago, like the Xperia play etc)
At the time of my Surface 2, I also had a touchscreen netbook, frankly I find the netbook easier to use, but that's when I had the touch cover which I didn't really get on very well with (Vivobook replaced by an Acer S7 Ultrabook)
Using Windows RT is actually really easy (Some help with 8.1, 50/50 split screen etc) with the Surface 2 like, being touch screen and all.
If you can live with the RT limitations, then I'd certainly get one, but it's not a product where you like everything about it, it's a product where you like certain things, and wish others were different.
I truly believe Surface 3 should be X86 only with an Atom/AMD whatever, then the Pro with the i5.
