- 20 Aug 2003
- Pembrokeshire
I always run with sidelights on, but primarily because the binnacle on my car is stupidly dark.
I saw a black Range Rover on the motorway the other week in fog/torrential rain.
Yep, no lights on. You could not see him at all, it was an accident waiting to happen. Half of me hopes someone drove into the side of him to change lanes.
I will have my side lights on whenever possible. The side lights on my car are led so there mega bright and standout.
In heavy rain I will even put fogs on so people can see me.
However the clue is in the name, FOGlights, not RAINlights i.e to be used in fog. This is something I wish people would grasp
226: You MUST use headlights when visibility is seriously reduced, generally when you cannot see for more than 100 metres (328 feet). You may also use front or rear fog lights but you MUST switch them off when visibility improves (see Rule 236). Law RVLR regs 25 & 27
236: You MUST NOT use front or rear fog lights unless visibility is seriously reduced (see Rule 226) as they dazzle other road users and can obscure your brake lights. You MUST switch them off when visibility improves.
Depends. Fog lights when theres heavy spray on the motorway seems fine. Its still reduced visibilty caused by water vapour![]()
I was always taught that you aren't actually supposed to drive on sidelights anyway as they are only meant for marking your car when parked.
Whether thats true or not I don't know but like you if I need my lights I put them straight to dipped
basically sidelights are there to make you visible to other road users, headlights are there for your own benefit. Personally I turn the sidelights on as soon as it starts going dim but hold off on the head lights until I actually need them.I do wish the police would have a good old crackdown on silly drivers who put their fogs on when visibility is not impaired.
Erm.
You know exactly what I mean and you're being incredibly pedantic.
I'll chuck the side lights on if it's light rain/not that bright and then mains on if it's quite bad rain or dark enough. rarely use the fogs unless there is actual fog/mist or raining so had on the motorway I can barely see anything
.full beams everytime, all the time!
lolI'll chuck the side lights on if it's light rain/not that bright and then mains on if it's quite bad rain or dark enough. rarely use the fogs unless there is actual fog/mist or raining so had on the motorway I can barely see anything
can't really think of any other reasons than the ones I stated
That "disadvantage" means people will pull out, having not seen me and end up with 42 stone of steel motorcycle (plus around 13 stone of rider) flipping up through their side window and into their face... or more likely, their children's faces.About the only disadvantage I can think of is that motorcyclists might lose their advantage of being contrasted against other vehicles with no lights on.
But should aditional responsibility rest with you?As the driver of a very small car, I'm extremely aware of the need to make it visible.
113
You MUST
ensure all sidelights and rear registration plate lights are lit between sunset and sunrise
use headlights at night, except on a road which has lit street lighting. These roads are generally restricted to a speed limit of 30 mph (48 km/h) unless otherwise specified
use headlights when visibility is seriously reduced (see Rule 226).
Night (the hours of darkness) is defined as the period between half an hour after sunset and half an hour before sunrise).
Laws RVLR regs 3, 24, & 25, (In Scotland - RTRA 1984 sect 82 (as amended by NRSWA, para 59 of sched 8))
