What are you cooling it with Raven? At 4.5ghz the temps are very good under p95.
Phanteks PH-TC14PE, ignore them temps they were only 15 minutes in to prime, after an hour they were mid 70's.
Hi, just seen the temps is that what you get for prime 4.5-1.28c >56'c to 66'c what cooling you using RX2?
Whats your room temp at?
Buy a cheap thermometer as it will give you a better idea how she runs regarding temps.
I'v just been online gaming MW3 About 2 hours room temp 21'c, CPU Core temps 35'c to 42'c with SLI 670 in loop as well.
Prime is no way representative of loads your average PC is under. I now render a long video to 1080p and run cinebench multiple times as well as browse the web, if it passes that it's rock solid stable imo.
