I got the card today and i must admit it has been somewhat a nightmare. It replaced my ASUS GTX 470 but when firing up some games they refused to load and 3D Mark just crashes.
I used the display driver uninstaller powered down the system then installed the new video card. Since games wasn't loading and crashes and what not i thought ok i will flatten the system and start from scratch.
Did that although i haven't got round to reinstalling the games yet 3D mark constantly crashes. So reset my processor from it's moderate overclock to factory defaults. Still crashes in 3D Mark after the last 7 hours of trying 4 different drivers, i have found out it's the clock speed of the GPU causing the crashes. Factory default is 977MHz, if i down that to 947Mhz it works fine. Yet i loop Heaven with extreme tessellation at 977MHz with the GPU maxed at 100% and doesn't crash.
Kinda strange i wonder if it is a BIOS problem or what, with only 30MHz factory overclock i wouldn't have expected to make so much of a difference in stability since people can typically get around an extra 100MHz before having to apply voltage.
Not even sure if i should RMA the card or what or if it will be fixed in a BIOS update? What would you guys do?
