- 12 Jul 2012
From what i remember in the past you have always had the Phanteks PH-TC14PE cooler, ive been looking at the Be Quiet 140mm fans as ive been considering changing some of the fans in my PC for quieter ones.
I accidentally came across a thread on Overclock.net when searching for some info on the Be Quiet 140mm silent wings 2 fans and the Dark Rock pro 2 cooler which had a post by you and your profile pic has a photo of the Dark Rock Pro 2 cooler.
Couple of questions for you.
1. Is their a way of mounting the Be Quiet Silent Wings 2 PWM 140mm fans onto the Phanteks PH-TC14PE cooler ?
2. How do you rate the PH-TC14PE against the Dark Rock Pro 2 ?
The reason i ask is that the most noise that comes from my case is from the Phanteks PH-F140TS fans on the PH-TC14PE cooler, i was seeing if i could make things a bit quieter hence the Be Quiet fans or cooler.
