- 6 Nov 2002
- London UK
Hi all,
My scenario is I have two folders containing matching files of different types, however the second folder has many extra files which aren't needed.
E.g.
Folder A
filename01.abc
filename03.abc
filename04.abc
filename08.abc
filename10.abc
Folder B
filename01.xyz
filename02.zxz
filename03.xyz
filename04.xyz
filename05.xyz
filename06.xyz
filename07.xyz
filename08.xyz
filename09.xyz
filename10.xyz
Is there a quick and easy way to remove the extra files from the second folder (i.e. filename02.xyz, filename05.xyz......)?
I have thousands of files to sort through so need an automated method.
Thanks
E.g.
Folder A
filename01.abc
filename03.abc
filename04.abc
filename08.abc
filename10.abc
Folder B
filename01.xyz
filename02.zxz
filename03.xyz
filename04.xyz
filename05.xyz
filename06.xyz
filename07.xyz
filename08.xyz
filename09.xyz
filename10.xyz
Thanks
