Breifly start car with no coolant?
7 Dec 2002
UK
Is it safe to start a car with no coolant briefly? I've just started an engine conversion and I'd like to make sure it starts before I start cluttering the engine bay with a cooling system. Will 20-30 seconds running be a problem?
I drove a Renault Laguna with no coolant in it before, it didn't finally seize until about 15 miles of driving. Impressive :cool:
I'm worried about heat building up differently in a block/heads with no water and also running the water pump dry.
Why?
("For the lols" is a perfectly acceptable answer :D)
It was an old crappy one which one of my friends parents were going to take to a scrap yard, me and a few friends decided to drive it around for the lolz when we were all about 17 :p
Not good for the engine or the pump
You could bypass the rad, and use a tline to fill it with water as a quick test.
Only works if he has connected up the pipes elsewhere though, which it doesn't sound like he has.
In saying that it should be a two second job, really don't see any issue with starting it for a few seconds though
A few seconds no problem.
I ran my crashed colt for about 15 mins with the radiator smashed to pieces though and it totalled the engine, knocking like a jack hammer after that.
I'd limit it to 10 seconds if I were you.
Or simply trust what you are doing and just get on and finish the rebuild, fill it with coolant, check for leaks, prime the system without the plugs in and then just get on and start it.
Just think about the fact the second you flick that key it'll be in the region of 130°C in there. If there is no coolant to wick away that heat, metal things start expanding rather more rapidly than desired...
