- 26 Aug 2004
Pros and cons for gaming and mining?
For mining the 290 will be the better card. In games though both perform pretty much the same. Though the 290 will support mantle in a few upcoming games which when running properly will give a boost. 780 will use less power and run cooler assuming you will be using a reference cooled 290.
Keep the GTX 780.
No point buying 290 with ref cooler as it throttles itself due to the heat, especially if you are mining.
Keep with 780.
I've gone from 680 to 290x and endless problems with black screens and seems pretty common fault with drivers.
Gone back to 680 and RMAing 290x
Only if you use the stock fan profile which is very lazy. A fan speed of 50%+ or higher is enough to stop a 290 throttling and running in the mid 80's.
It was too loud for me even at that speed.
