- 10 Jan 2014
Hi, Any good advice on the best 120mm silent fans ?
There to go on My H100i
Cheers
Cheers
Corsair SP120 quiet editions are pretty good. I have three of them in may 650D case & you can't hear them.
They don't move huge amounts of air, I think it's about 35cfm, but I did run one on my 4770K @ 4.5ghz, & it kept temps down to low 70c's at load.
Try Enermax fans:
YOUR BASKET
1 x Enermax T.B.Silence PWM UCTB12P 120m Fan £11.99
1 x Enermax T.B.Silence Manual UCTB12A 120mm Fan £10.98
1 x Enermax Cluster UCCL12 120mm Fan £9.98
1 x Enermax Magma UCMA12 120mm Fan £9.98
1 x Enermax T.B.Silence UCTB12 120mm Fan £6.98
Total : £49.92 (includes shipping : FREE).
I will be using those slow ones in push pull configuration at 100% speed, because they are so quiet.
Gentle typhoons ftw lol
I doubt the Corsair fans would be classed at silent since they spin at 1450rpm have found you need to go around 800rpm~ for most fans.
Trouble is they are not made any more - difficult to get.Great fans for rads though.
