- 13 Nov 2003
- Chester
u can be the better player and still lose.
That's how I feel when we play Rob.
Messsssssssssiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii
Honest answer, you'd be stupid if you did that!
You want someone Neutral/good all rounder and someone attacking, could go SIF Cabaye & Ramires, but whatever we tell you will be wrong, then questioned
For anyone who has/had a Bundes team, using 433-4 for it and tempted to switch up the front 3, I may try Robben again for Blasz, then could try Ribery over Reus or try out SIF Lewandowski, Reus is so solid but at the same time Ribery could be worth trying out again, was nothing wrong with him last time I had him in my French team, just the Reus isn't really doing anything wrong!
I think the Bundes team is the one team I keep around no matter what now, going to try Gotze, IF Kroos, IF Mkh at CAM over Draxler to see if anyone grabs my attention, at least the defense is as perfect as it can be without IF Alaba & TOTY Neuer!
, 82 to 99 stamina, most of his skills are up by 4 or 5. Seems well worth a look. Total stats 481
I really wanted IF kroos to be good, his NIF was so lethal, sadly it just didn't happen, he did absolutely nothing for me, Nif always used to be available in space, IF just wasn't. I have noticed a few others say the same, i though i was doing it all wrong so i checked out a few reviews.
Gotze was good but draxler was better for me, more rounded and available to shoot.
If it was me id plump up the cash for IF Alaba, his nif always impressed, he was so solid and looking at his in depth stats he actually has a nice bump across the board so i could imagine him being a bit of a beast. Reactions up from 84 to 93, 82 to 99 stamina, most of his skills are up by 4 or 5. Seems well worth a look. Total stats 481
The stats for NIF aren't right on FH/FW so the IF doesn't provide as much as a bump as you think. Check the in game stats yourself by going to Squad -> Bio.
Really, such a shame. you think they would make a point of getting something like that correct wouldn't you.
I appreciate the suggestions but Ramires is a CDM isn't he? I'd have to manually change him to CM?
The stats are from the career mode database. So comparing say Reus to Ribery is fine because the stats are relative but comparing NIF Reus to IF Reus is not valid due to the NIF stats being wrong.
I personally think only SIF becomes worth the upgrade in stats terms.
You don't often need to. Nothing stopping you playing a CDM in the CM slot. It'll still get max chem with either manager / loyal link.
It is really rather enjoyable scoring goals from the kick off glitch against people that just spam it against you with no success.
.What's the kick off glitch?
88 Suarez is cheaper than Aguero now... He poo?
