**New Price Corsair Vengeance 2100 Wireless Dolby 7.1 Gaming Headset **
7 Feb 2011
Stoke on Toast
Have a great deal for you guys on some stock that is due to land any time. Corsairs flagship wireless Gaming Headset for under one hundred pounds!
Corsair Vengeance 2100 Wireless Dolby 7.1 Gaming Headset (CA-9011125-EU) @ £89.95 inc VAT
The Corsair Vengeance 2100 delivers high performance gaming audio without the wires. The powerful 2.4GHz connection gives you up to 40 feet of wireless range and up to 10 hours of battery life. Accurate Dolby 7.1 multichannel audio helps you pinpoint your enemies’ location before they see you. Large 50mm drivers offer better bass response and crisp, clear midrange sound and the noise cancelling microphone lets you be heard loud and clear. The closed-back, circumaural earcups reduce environmental noise for a more immersive gaming experience. Plus the earcups feature microfiber-covered memory foam earpads for hours of comfortable gameplay.
Features:-
- 2.4GHz wireless audio - High performance gaming audio without worrying about wires.
- Dolby 7.1 surround - Accurate multi-channel audio helps you locate opponents even if you can¡¦t see them.
- Large 50mm drivers - Better bass response and crisp, clear midrange for more audio quality and a competitive edge.
- Designed for comfort - Microfiber-covered memory foam earpads and a padded headband let you play longe
- Noise cancelling microphone - Be heard loud and clear, whether you¡¦re playing or just chatting between matches.
- Large diameter, circumaural earcups - Blocks distracting sounds and keeps your head in the game.
Specification:-
Headphones
- Frequency Response: 20Hz - 20 kHz
- Impedance: 32k Ohms @ 1 kHz
- Drivers: 50mm
Microphone
- Type: Unidirectional noise cancelling
- Impedance: 2.2k Ohms
- Frequency Response: 100Hz ¡V 10kHz
- Sensitivity: -37 dB (¡Ó 3 dB)
Wireless
- Range: Up to 40 feet (12m)
- Battery life: Up to 10 hours
Was £119.99 Inc. VAT
Only £89.95 inc VAT.
ORDER NOW
I'm a bit of a basshead with my music, aswell as I like to know what direction my enemy is, I can only assume that 50mm Driver delivers in that aspect?
How many speakers do these have?
I have 5.1 Roccat Kaves (with 40mm Driver, 3 speakers) and I actually had to turn the Bass down when playing BF4... If anything these should be deeper!
Music wise they're fine on the standard settings (EDM - HC/Freeform/Gabber listener and ex bedroom-DJ) ;)
This looks great. I wonder if the 50mm drivers need a discrete sound card to power properly though?
I've got an older Vengeance headset and they are horrible compared to my new DT 770 Pros.
Build quality, materials and comfort are all much worse. DT 770s are well worth the extra £30.
Completely agreed with above. Any audiophile grade headphones are substantially better than anything with the words gaming attached to it.
I went from Sennheiser HD 25's (standard DJ'ing kit) to Roccat Kave 5.1's and find the quality on-par, obviously the surround is amazing but the clarity and sound quality is equally as good! I would expect the Corsairs to be of the same quality.
