Hello guys,
I have some weird things happening and I have been trying different setups since thursday to set everything up perfectly with no luck so I seek your advice.
Firstly my setup looks like this: I ha e a xonar d2x installed optical cable running from soundcard to the mixamp and my a40 is connected to the mixamp. Now the thing is if I set my primary audio device to speakers with the DD button OFF on the mixamp I get sorround sound perfectly on all channels but character voices and lot of sounds are strangely distorted. Amazingly if I press the DD button on the mixamp ON it just goes stereo.
I tried switching my primary device to the xonar optical spdif. It gives sorround sound ( almost, ill tell you in a sec). No distortion, but in the dolby test demo there is no FLE channel sound. Also same goes for the DD button in the mixamp if its on no sorround if its off there is sorround.
I thought the mixamp should enhance the 5.1 it receives from the soundcard and not revert it lol.
Any help would be appreciated and sorry for the long post but I had to explain for you guys to see whats happening.
P.s: Also the xonar desktop app should be set alright its on 6 or 8 channel same thing and has headphones set and dolby digital live.
Cheers,
Alex
Cheers,
Alex
