Cleaning cloth seats
11 Dec 2005
Cheshire
I have light grey cloth seats in the CRZ and getting stains out of them is proving an issue.
I keep using autoglym interior shampoo and just making larger stains.
Looks like I've spooked all over the seats, so not very impressive to look at (or very impressive to some).
Help.
What kind of stains? Is your car a disability car? Are you incontinent?
Stains from where I've royally screwed up trying to clean the seats for no reason other than wanting to clean the seats.
No I didnt **** myself, it's a hybrid not a supra and at least the supra had leather for wipe clean purposes ffs.
Nath, is the stain one of those which just seems like a wet patch that hasn't dried up?
I've used that AG cleaner before, same result. I'd just wet vac the whole seat and hope for the best, or just have a valeter do it since I don't have a wet vac :p
Try a wet vac like that man. Should sort it. Had the same problem with my ATR where it looked like I had bust a load all over the seat. I left it as I cba cleaning it when I got rid of it. Mate tried this and it worked for his seats.
Take it to a local car wash, they shouldn't charge too much. Check on gumtree too for people offering that service. Last resort is a laundrette where you can hire one out for a day. May as well do other cars/home sofas or whatever you want.
looks like a wet vac or steam clean is on the cards.
How much would one expect to pay for such a service?
I think one of the car washes in Goldenhill will do this for about £15, as well as a general clean. There's probably a local specialist valet business that could probably do a better job, someone else local might know better.
I've used a Wet VAC when the window was left open in the middle of a storm. It helped to get rid of excess moisture and got the seats like new, and this is in a 2001 Clio which looks like it had never had the interior cleaned! This was using the Vac which our family share, took about 20 mins.
Cheers man, will look around then. The car isn't dirty at all, so it literally would be just to get the jizz like stains out the seats.
I've had really good results with AutoBrite FAB and an upholstery brush. Cleaned up about 12 years worth of grime in my mums Fiesta with minimal effort.
