I'm not 100% sure Silent Wings 2 can be used as a radiator fan because of the unusal mounting method. If it does, you will have to use the rubber mounts as the hard plastic ones can't be screwed all the way through.
I've seen shadow wings used on a h100 a couple of times before though
Cheers . They will be here in the morning so will look then to see if they will work![]()
Before you screw one fan in (as the screw will probably thread the rubber mount), check that you can fit 2 of them side by side. I think the edges are out a tiny bit further than a standard 120mm fan.
