Watercooling parts for workstation build
6 Oct 2009
London
Hi..
This is my workstation, discussed here:
YOUR BASKET
2 x XSPC AX480 Quad Fan Radiator (Black) £109.98 (£219.96)
2 x XSPC RayStorm CPU WaterBlock (Intel) Copper £104.99 (£209.98)
1 x XSPC Razor GTX Titan / 780 / 780Ti GPU Waterblock £94.99
1 x XSPC AX360 Triple Fan Radiator (Black) £89.99
1 x OcUK Tech Lab - XSPC D5 Vario Pump & EK-D5 X-TOP CSQ Plexi Combo £84.98
1 x XSPC AX240 Dual Fan Radiator (Black) £74.95
1 x DEMCiflex Dust Filter Kit for Corsair 900D - black/black £54.95
1 x Aqua Computer Aquainlet Pro 150ml £35.99
1 x XSPC Razor GTX Titan / 780 / 780Ti / 770 Backplate £24.98
3 x BitFenix Recon Internet-Connected Fan Controller (Black) £23.99 (£71.97)
25 x Noctua NF-F12 PWM 120mm Focused Flow PWM Cooling Fan £15.98 (£399.50)
3 x Koolance LIQ-702 Liquid Coolant Bottle, High-Performance, 700mL (UV Blue) £11.99 (£35.97)
2 x XSPC HighFlex Hose 7/16" ID, 5/8" OD, 15.9/11.1mm, 2m, Clear £5.99 (£11.98)
18 x XSPC G1/4" to 7/16" ID, 5/8" OD Compression Fitting (Black Chrome) £3.19 (£57.42)
Total : £1,477.33 (includes shipping : £8.00).
Any comments are appreciated.
I have one question: why spend money to watercool CPUs that can't overclock?
Also, you will need approx. 1.5L-2L of fluid for all these rads plus tubing, not just 700mL.
Other than that, if you will insist on watercooling Xeons, I'm sure you don't need that many radiators and 27 fans.
Silence!!
Just so you're aware.. the 360 radiator will not fit in the case with a 480mm & a 240mm in the bottom of the case (assuming you're going to try to front mount it)
I presume you meant to have 2 CPU blocks if you're running a dual CPU setup
It's for silence and running the fans at the lowest rpms. Thanks for the correction for fluid :)
Silence!!
Thanks for the corrections, I initially chose another waterblock and replaced it, forgot to add 2. Also corrected the radiator (so 4+4+2+2), and the number of fans accordingly. Edited the list in the first post.
