** AMD MEMORY: GREAT AESTHETICS & PERFECT FOR YOUR AMD APU/PC SETUP!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OcUK is bringing you AMD's memory designed for their FX and APU processors, OcUK and Caseking will be the first with this great looking memory in Europe. Obviously it is ideal for AMD CPU's but also looks pretty good as well with Black PCB along with black/red heatspreader design. Looks awesome in an Asus ROG or MSI Gaming mainboard. :)
AMD Gamer 8GB (2x4GB) PC3-19200C11 2400MHz Dual Channel Memory Kit (R938G2401U1K) @ £77.99 inc VAT
AMD Memory is designed to deliver memory that is optimized and certified for AMD Platforms and components and also delivers quality and reliability to compatible chipsets and processors from other manufacturers. High-quality DRAM parts (no ETT) help ensure no dropouts and no data loss. With AMD memory you get the performance you need for all your applications.
Features:
- Black PCB
- Black high performance heatspreaders
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- CAS Timings: 11-12-12-31
- Dual Channel Kit: (2x4GB)
- 100% tested at 2400MHz in AMD 990FX & Kaveri APU based motherboards
- Lifetime Warranty
Only £77.99 inc VAT.
ORDER NOW
AMD Gamer 16GB (2x8GB) PC3-17000C10 2133MHz Dual Channel Memory Kit (AG316G2130U2K) @ £149.99 inc VAT
Features:
- Black PCB
- CAS Timings: 10-11-11-30
- Dual Channel Kit: (2x8GB)
- 100% tested at 2133MHz in AMD 990FX & Kaveri APU based motherboards
- Lifetime Warranty
Only £149.99 inc VAT.
ORDER NOW
AMD Gamer 8GB (2x4GB) PC3-17000C10 2133MHz Dual Channel Memory Kit (R938G2130U1K) @ £73.99 inc VAT
Features:
- Black PCB
- Lifetime Warranty
Only £73.99 inc VAT.
ORDER NOW
AMD Gamer 16GB (2x8GB) PC3-14900C9 1866MHz Dual Channel Memory Kit (AP316G1869U2K) @ £139.99 inc VAT
Features:
- Black PCB
- CAS Timings: 9-10-9-27
- 100% tested at 1866MHz in AMD 990FX & Kaveri APU based motherboards
- Lifetime Warranty
Only £139.99 inc VAT.
ORDER NOW
AMD Gamer 8GB (2x4GB) PC3-14900C9 1866MHz Dual Channel Memory Kit (AP38G1869U1K) @ £67.99 inc VAT
Features:
- Black PCB
- Lifetime Warranty
Only £67.99 inc VAT.
ORDER NOW
Will they actually provide a performance benefit over another equally clocked set from a different manufacturer? Im using corsair at the moment, but would it be worth my switching to this?
I think its more of a guarantee you'll get these sticks up and running at the rated speed with minimal hassle on supported AMD platforms, rather then buying Intel XMP rated sticks that may or may not perform as advertised on AMD's various platforms.
Ah ok, makes sense. Been wondering how long it would take AMD to make a pseudo-xmp. Luckily my vengeance works well :D
