***The Vapers Lounge***
Status
Not open for further replies.
The EU are scum to be honest, hypocrites, they make this legislation banning advertising etc. and at the same time I have noticed loads of marketing from the tobacco companies for "cig a likes", the whole thing is about money and tax, nothing to do with "public health". They just want all products taxed and regulated from big brands, while messing it up for the smaller brands and retailers.
I ordered the Evod starter kit that was recomended earlier in this thread(quite a while ago as I had it bookmarked for a good month) and I must say I am very much liking the change.
from a personal point of view I find it crushes any cravings. The only part I am coming to terms with is that there is no start and end, like say the moment you light a cig to when you put it out.
I am not truly sure how to put it, but do you guys say use it for a few mins and put it away till later or will you just over a period of time puff away?
The Evod came with quite a few coils, how often should they be changed? Plus how do you clean it out and how often. I am sure I have seen this info in this thread but cannot find it now. :D
Plus a big thankyou for all the info in this thread it helped me change over, and I am already a big fan of no longer having the smell of tabaco on me.
EVOD 1000mah + C9V micro-D RDA + 1.7ohm microcoil + cotton =
Liking this budget setup I got, I think it actually vapes better than the Vamo V5 + IGO-W I had, because it doesn't have the PWM rattlesnake or tight draw, also it only cost me £20, proof that you do not have to spend a lot to get a nice vape. Sorry about the appalling camera quality.
What is a PWM rattlesnake in english? ;) Pulse-width-modulation... erm.... I only know that in synthesizer terms and it would be awesome if my Zmax went VVVZZOOOOBBBB-B-B-B-BBBBffff!!!
On the Vamo it has PWM and it makes the vape worse, also sounds like a rattlesnake. I used my friends Zmax and it was not as noticeable. Sort of like on PC monitors that have bad PWM.
Any recommendations on menthol flavours?
Also what to try after menthol?
When switching "juice" do i need to do anything other than wash the tank out?
Just to make sure you still have to add VG to the PG Nic based liquid?
thanks.
Yes. As 100%pg would give you no vapor.
Just get a bottle 100ml of VG, if you mix at 50/50 then it's enough to make 200ml of juice.
Don't forget to get a couple of syringes and bottles.
I get my 10,30 and 50ml dropper bottles from creamsupplies. I use baby bottles and old cough medicine bottles for my 100ml mixes.
Chefsvapor is very good for flavourings.
Easiest way is to use http://monwiki.fr/efvi/banners.html
The numbers are fairly low right now. This isn't just another petition this has legal power (why it needs such big numbers and from many EU states)
3.5% :/ Signed. Why we should have to be doing this I don't know, we are voting here for nicotine in vapour to not be banned, whereas we can go and buy cigarettes no problem.
Yeah numbers have always been a problem. We know there are enough vapers out there, they just don't all go on forums. Very few of these have managed to get to the EU, one about clean water did. Anyway anyone can sign so worth asking your family to sign to. I family have all signed, while I'm the only one vaping.
Going along side this is a legal challenge, it can't start until a member state implements they TPD. The court in that state has to refer it to the EU one and we should win that. At least every court has rule in favour until now. They don't seem to bend the facts the way MEPs have. You got to love the EU, smoking banned everywhere but you can smoke in the MEP bar.
Status
