King Of PSU's ? Suggest me top line Power Supply
16 Sep 2013
Gloucester
Hi Guys,
So my Corsair AX1200i is failing on me - shout down my system in various times , i contacted corsair and they don't have same in stock till end of march so they will refund me nice money for it , and here comes your help
Can you suggest me the best of the best power supply for highest up system with overclocked 4930k and 3 gtx 780ti , so i need at least 1200w
with PSU should i get ?
I dont really need any fancy digital psu , i just need good psu to hold such a huge system
Thank in advance
From OcUK http://www.overclockers.co.uk/showproduct.php?prodid=CA-025-SS&groupid=701&catid=123&subcat=2383 IMO unfortunatly they don't really stock any of the others I'd reccomend at this time.
Word of warning with the SuperFlower ~1200watt models while decent units if you really are using the best part of 1200watt load without spreading it enough over the connections you can see some odd voltage regulation issues leading to melty plugs.
Not only the Superflowers that can melt plugs - http://forums.overclockers.co.uk/showthread.php?t=18583951
^^ You might have fallen foul of the rev1 to 2 change over where some of those PSUs were sent out with the wrong revision cable pack :| (don't have the right plugs for all the sockets and/or don't fit quite properly). Bit of a poor show by Seasonic. I'd still normally reccomend them over pretty much anything else now though.
