So been getting my head around Haswell clocking and struggling to understand all the differences between it and SandyBridge.
I've managed to get it stable at 4.5ghz, now when I say stable that's two passes of Intel Burn Test + gaming. I run IBT to as it usually identifies if i've got enough volts and stop me cashing mid-gaming, although this isn't always the case.
Currently using the following;
- UNCORE 4.3
- VDROP 100%
- VCORE 1.286 (1.304 with above)
- VRIN 2.0
- XMP RAM with force 1.65v as board always seems to run it lower.
This is fine, but if I try to go to 4.6ghz it will boot into Windows but will instantly fail IBT with whea_uncorrectable_error which leads me to believe its VCORE - but i'm not 100% sure due to all the new voltage options we have on Haswell.
I've not gone higher than 1.3 yet and was wondering if there is anything else I should try first or should I just accept that i've hit the limit.
- UNCORE 4.3
- VDROP 100%
- VRIN 2.0
