That auto-overclock has worked pretty well tbh.
I've been poking around my BIOS tonight, and got 4.5GHz stable now, with a 4GHz Uncore.
I'll give you my settings for 4.4GHz, here's everything I've changed in one list:
Multiplier 44
Uncore/Cache ratio 39
XMP enabled (If you haven't already enabled this, do it first, then restart and go back into the BIOS.)
Power settings:
Load-line Calibration (LLC)- Extreme
PWM Phase control- Extreme
CPU power settings:
Vcore 1.20v (You may want to go for 1.21v for a little added safety...)
Uncore/cache 1.175v
System Agent +0.250v offset
Everything not mentioned is left on auto.
Been using these settings for a while without a single problem. Just got 4.5GHz/4GHz tonight by tweaking the vcore to 1.21, and uncore to 1.180.
See how you get on with 4.4GHz first though. Bang in all the settings in one go. Good luck, see you on the other side...
