My girlfriend's 207 1.4 8V (TU engine) is displaying the apparently common head gasket oil leak symptoms (I think the 1.1 engine along with the 1.4s in the 106 and 206 were susceptible too?) and I fancy having a crack at changing it and doing the cam belt at the same time as a bit of a challenge to myself.
Has anyone done one of these engines? What do I need to know? Is it simple for someone who is not scared of a spanner but who doesn't have a massive wealth of experience?
It looks pretty easy in principle because of the simple and accessible engine configuration; Remove stuff, remove rocker cover and cam belt, lock the timing, undo head bolts, lift off head, clean off old gasket, apply new one, bolt head back on to the correct torque and in the correct sequence?
I was going to set aside a couple of days when the weather improves to tackle it.
It's a horrid engine and to me, the 'TU' stands for 'Totally Useless', but hey ho. The rest of the car is fine.
