Permabanned
- 19 Nov 2011
Hello!
First off, I am exaggerating quite a bit. Its nothing like a hoover... but it does get pretty loud.
When its not in full use, but turned on with say the music going or a film, it gives out a slight hum. Certainly noticeable but not unbearable... couldn't sleep with the PC on mind. When I play a game on it, like Titanfall (beta was awesome huh?!) it sounds like its going to take off and if I place my hand over the top of the case where there is a grill, I can feel quite a bit of temperature there.
Cooling wise, it has a stock CPU cooler on its 4770 and just 2 of the fans that came with the case... I don't have any experience with air flow so I placed one at the pack pulling air out of the case and another on the top, doing the same. I assumed that this is okay as the air will be pulled in from the front of the case as there are some vent holes.
Is this what's causing the temps to get high, which then make the fans go into OVER 9000 mode? Or do I need more fans? If so what are some decent, price friendly ones? Or do I need a CPU cooler? I kind of get the feeling that its the GPU that is getting hot not the CPU... but I'm not sure.
Any help would be grand!
Cheers,
Grady
Cheers,
Grady
