**Official THIEF-Incorporating AMD™ Mantle™/True Audio™/Bench mark Thread**
Status
Not open for further replies.
Caporegime
12 Jul 2007
United Kingdom
That's weird, crossfire has started working on Thief. Nixxes must have patched it in via yesterdays patch. Scaling is poor, but its definitely working. Will get a quick stock benchmark up shortly. Apologies for blaming AMD.
5 Sep 2011
Surrey
Not looked to see its scaling for me on the green team but performance is flawless. I'm a stickler for low res textures though and this game has a few. Was expecting a bit more, but still a good looking game.
Caporegime
20 May 2007
Surrey
It is a good looking game but still a disappointment for "next gen". We really need some Unreal Engine 4 games to start coming out. What is the first game to use UE4?
5 Sep 2011
Surrey
I'm not sure about the fundamental differences with ue4 but it doesn't really look like it's had much uptake yet besides the demos Epic have created themselves. UE3 is obviously just in most devs comfort zones
Caporegime
12 Jul 2007
United Kingdom
Well i managed one quick run and now the game won't even load. Tried verifying files on steam, tried everything i can think of. Just get a black screen and nothing happens. Can alt tab out and carry on using the pc, but the game never loads. Thief.exe uses 390mb of ram and then stops, as well as 40% cpu but nothing else happens. Did some googling and its a known issue supposedly. Tried all the fixes listed but none work. No idea if my score is correct or not as i only got to run it once. Why it worked once and then never again, no idea. :D
[email protected]
290 crossfire 975/1250
14.2 Beta
Caporegime
12 Jul 2007
United Kingdom
At a quick glance that looks about 40-45% scaling. Think Gregs Titan sli showed similar scaling.
I can probably better that score a bit without overclocking, but i was not expecting to only be able to do one run. I'm going to try redownloading the game tonight, but it feels like a profile or config file has become corrupt or something.
5 Sep 2011
Surrey
Stock run for now. Will do some overclocked runs tomorrow.
1440P
780Ti Tri SLi
4960 @ 4.0
Scaling is fairly non existent over 3 cards
1080P
Caporegime
12 Jul 2007
United Kingdom
Reinstalled to a different hard drive and its working again, yay. As i ran the game it said error syncing to steam so i reckon the steam cloud had a corrupted profile or something.
OP
30 Mar 2010
Under The Stairs!
Scores updated, some aren't included as not enough info, if anyone wants them included, quote them with clocks please.
Matt, seriously, you need a new psu bud:
290 CrossFire@almost stock for BM'ing=
;):p:D
OP
30 Mar 2010
Under The Stairs!
Just an update after checking if 3D works on AMD after the update, no it doesn't, the 3D option is now greyed out.:o
On the other hand it's looking really good on 3D through Tridef with high fps, a much needed improvement on the visual aspect using 3D.
Looks like Mantle will be a no go for me as Tridef will no doubt be better than the in game 3D anyway, so looks like I'm just waiting on TA then I can start playing.:D
Daylight, it will be released on April 8th:
Caporegime
20 May 2007
Surrey
;):p:D
I have updated my post with the overlock for my cards so they can be added to the dual gpu list now :)
5 Sep 2011
Surrey
;):p:D
I didn't plus no point as the game supports multi GPUS about as well as my nans stove. More like Gaming Devolved. You've added my 1440p result to 1080p mate.
Stock clocks are 980/3500
Status
