- 21 Sep 2003
Hi folks
After 6 years of relatively-faithful service, I have decided it is time to look to go for a new build. My current system is as follows:
Is anything worth saving? My initial thinking would be case/PSU/DVD drive/sound card, but then again maybe a 6-year old PSU isn't worth risking in something new, and perhaps there are better sound cards out there that will output 5.1 (the X-Fi never did on Vista over optical due to a never-fixed driver issue).
Anyway, ideally I'd like to keep thinks to around £800, but can stretch a bit further if needed. It will be used for 1080p gaming, no higher resolution than that and if we are going for a wishlist, then I'd like it to be relatively quiet and run low temps.
Considering that build up above was about the last time I looked into anything PC-wise, I'm well and truly out of the loop, so all suggestions welcome!
Western Digital Caviar Blue 500GB SATA-II 16MB Cache
OcUK GeForce 8800 GTX 768MB GDDR3 HDTV/Dual DVI (PCI-Express)
Corsair XMS2 4GB (2x2GB) DDR2 PC2-6400C5 TwinX Dual Channel
Intel Pentium Dual-Core E2200 "LGA775 Core 2" 2.20GHz (800FSB)
Microsoft Windows Vista Home Premium SP1 64-Bit
Tuniq Tower 120-LFB CPU Cooler
Pioneer DVR-212DBK 18x DVD±RW SATA Dual Layer ReWriter
Creative Sound Blaster X-Fi Xtreme Audio 7.1 Sound Card
Antec 900 Nine Hundred Ultimate Gaming Case - Black
Corsair HX 620W ATX Modular SLI Compliant Power Supply
Abit IP35-E (Socket 775) PCI-Express DDR2 Motherboard
Western Digital Caviar Blue 250GB SATA-II 16MB Cache
