Right if anybody is using a EK DCP 4.0 Pump (12v) use one of these Akasa 3-Pin Noise Reduction Cable. Had one handy it works a treat it has
not effected my temps at all see sig. But it dampings the pumps noise just that little bit making your case even quieter with the reduced
pump speed its cooler. Which should help the pumps reliablity and life span which can't be a bad thing.
Akasa 3-Pin Noise Reduction Cable 12V to 10V - £1.99 inc VAT
http://www.overclockers.co.uk/showproduct.php?prodid=CB-082-AK&groupid=1929&catid=153
