- 7 Mar 2005
- LU7
I've been given a colleague's Seagate external USB hard drive that isn't working in Windows. We've tried it on 3 computers and none of them will properly see the hard drive. There are some files that we need to access and, unfortunately, there are no other copies or backups!
When I tried it on my work PC, Windows took ages to install the Seagate USB driver and eventually failed. With my colleague's permission I removed the hard drive from the enclosure and tried it in my SATA external dock where we had pretty much the same problem. I had hoped that the fact that the USB connection on the side of the enclosure was a bit loose would mean that that was the problem.
The only thing I can think of to do tomorrow morning as a possible fix is to plug the hard drive directly into my PC so that it's connected by SATA cable to the motherboard and not going through a USB connection.
Failing that are there any other suggestions I could try to see if we can access the files? When I leave the hard drive in the SATA external dock, the drive powers up and I feel it spinning inside; however after a while it all dies down and there's no way of getting anything happening again.
