- 1 Sep 2013
- Darwen
It'll just make already hard to catch criminals, harder to catch.
obviously never seen robocop...puny human
Jumping over the building is easy, compressing the fall damage to a point where every bone in your body doesn't shatter on impact, that's the difficult part![]()
Hell yes!
Although will we survive that long...
"Another Japanese company, Cyberdyne, has developed its hybrid assistive limb or Hal system, a range of machines designed for rescue recovery or "back load reduction" in the work place."![]()
Be like "do you even lift robot-bro?"
and power you can use good ol' ic or fuel cell or even nuclear battery.
Robro?
power supply troubles? why not make it bigger, maybe the size of a jcb or somesuch, then all the micro tech like fingers etc will be easy because they're bigger, and power you can use good ol' ic or fuel cell or even nuclear battery.
we have the technology. i recall watching a clip of a device that can let you 'feel' digitally, ie you could for example touch something that doesn't exist outside of a cad model [and this was 5 years ago]. large scale hydraulics are everywhere so power distribution isn't a problem and as i said power isn't a problem and we already have the likes of a force feedback joystick for a computer, whats so different about a whole body input device?
as for control devices, this is a pc forum and i'm sure something the size of a jcb can have a couple of xeon's stuffed in somewhere...
