- 3 Mar 2006
- Atcham, Shropshire
As the tech advances they will figure all this stuff out, All this heavy lifting etc is a long way off. If I had the answers I' be building it myself
while Cyberdyne and Ekso Bionics - which developed the Hulc originally - offer similar devices
Jumping over the building is easy, compressing the fall damage to a point where every bone in your body doesn't shatter on impact, that's the difficult part![]()
that will come as part of the 2.0 upgrade lol along with optional mini gun and rockets
You been watching Pacific Rim?
but the question is why?
why have a very expensive very complex, very fragile JCB sized robot, when either a jcb or a forklift will do?
cars are very easy to get out off
it's not like your strapped in.
for example it catches fire so hydraulics fail, how do you move your self to undo the straps/locks?
the thing is going to weigh a few hundred pounds it's self.
if it ere as trivial as you're making out we'd already have them working.
heck we had massive unexpected errors with robotic arms when they were first used and they ARE trivial compared to a mechanised suit, for example when they went into gimble lock, simple solution is flip the gimble 180 degrees.......what do you think happened when a massive robotic arm decided it needed to flip one of it's joints 180 degrees in a fraction of a second?
Shirley, that's not right? The initial acceleration would be just as violent as the deceleration when stopping?
Ie, the acceleration needed to achieve (in a fraction of second) an initial velocity sufficient to get over the building would destroy your organs before you even got off the ground?![]()
Thing is, you're trying to find a solution to a problem which we haven't got round to actually doing anything about yet.
