Ford Focus 2006 manual regarding oil checks
Check when refuelling
• Engine oil level. See Engine oil
check (page 218).
ENGINE OIL CHECK
WARNING
Do not use oil additives or other
engine treatments. They are
unnecessary and could, under
certain conditions, lead to engine
damage which is not covered by
Ford Warranty.
The oil consumption of new engines
reaches the normal value only after
approximately 5 000 km (3 000
miles).
Make sure the vehicle is standing on
level ground. Check the engine oil
before starting the engine. If the
engine was running, switch it off and
wait some minutes for the engine oil
to flow back into the sump before
checking it. Pull out the dipstick, wipe
it with a clean, non-fluffy cloth,
re-insert it completely and pull it out
once more.
If the level lies between the marks,
there is no need to refill. Hot oil may
exceed the MAX mark by some
millimetres due to thermal expansion.
If it lies at the MIN mark refill using
only engine oil meeting the Ford
specification.
