Catzilla 1.0 Benchmark Scores
This bench is totally broken for me now. Blacks out in certain parts. It's the only thing that does it, so it's definitely not the card.
When i changed to the latest whql drivers it does that, When going back a few revisions its fine and scores a bit more.
576p:
GTX 780 1267/1750 (air), i7 4770k 4.2 ghz (air)
720p:
GTX 780 1228/1706 (air), i7-4770k 4.2 ghz (air)
1080p:
Couldn't run on 720/1080 with the higher clocks, crash every time :(
576p:
720p:
1080p:
And on the scoreboard.:)
I am sure that helps but I don't think the CPU clock really has much to do with it. My logs read lower usage by the CPU and GPUs than I expect with SLI.
CPU clocks are needed with 720P for sure. Especially at 1775 mhz. I ran 6250 for all GT's with a new binned CPU I found yesterday.
3 Ti next!!! Lets see how that one scores!!
A great score 8 Pack to remain top of the world in Catzilla 720p 2GPUs with a healthy 4737 lead, and good luck for 3GPUs run :)
Looks like new bin chip with improved IMC has helped there. The R4BE has BIOS out today to improve stability, version 0602. Direct link to BIOS.
Yeah nearly 5K lead gotta be happy with that. Not tested 0602 yet but will try this tomorrow with another good chip I have.
Need to figure out how to get these new stepping to OC consistently over long periods. My previous benching chip could bench full speed for like eight hours the one I used on this run takes a lot of messing with.
Watch me bench ASUS Matrix cards live from OCUK on our Twitch channel on Tuesday.
A lot better but still a fair amount away from Nicks Classy.
4960@ 4750 (125BCLK) My cards just don't like as much as 130BCLK in certain CPU intensive benchmarks unfortunately.
780Ti SC ref @ 1345/1900
Nice score and on the scoreboard.:)
You really need to get the BCLK up a bit to overclock the PCI-E slot, have you tried 128 or 129. Using 125 is much the same as using 100, there is no overclocking going on with the PCI-E slot.
